blueeyes243
#1 Posted : Wednesday, May 1, 2013 5:37:49 PM(UTC)
blueeyes243
I have a whirlpool refrigerator I changed the start device with the overload, the compressor seems to be hot when I touch it and I am still getting the issue where the light inside shuts off and the fridge makes a clicking noice when I turn the theromstat off the fan also starts to blow with the theromstat off but when I put the theromstat on 3 which is the normal setting i am wondering if my compressor is bad?Whirlpool refrigerator model number ET8WTEXVQ02:( :(
#2 Posted : Thursday, May 2, 2013 3:59:36 PM(UTC)
Seems like you have a burnt wire someplace in the fridg. This will Usually cause low voltage to the compressor that will damage it and make it hard to start.
The problem most likely is a burnt wall outlet.
ikedeen
#3 Posted : Thursday, May 2, 2013 7:38:31 PM(UTC)
ikedeen
Sounds like the PCB (Main Control Board ) is faulty.
Check condenser fan; might need to be replaced also.
#4 Posted : Friday, May 3, 2013 12:25:07 AM(UTC)
I would not replace the expensive board till the fridg is checked out for "problems" mentioned.
ikedeen
#5 Posted : Friday, May 3, 2013 7:15:50 AM(UTC)
ikedeen
Agreed, must first find source of problems.
If the "Clicking" is from the PCB, then possible faulty capacitors, which affects the overall function of fridge. The condenser fan may malfunction also.
I repaired my PCB which had POOR QUALITY PARTS (capacitors made in Taiwan) GE refused to take responsibility.
ikedeen
#6 Posted : Friday, May 3, 2013 6:09:26 PM(UTC)
ikedeen
My previous response was not posted.
Was it OFFENSIVE? explain please.
I do not profit in any manner in this forum.
#7 Posted : Saturday, May 4, 2013 12:50:37 AM(UTC)
You might try a portable fan to cool the compressor. I assume you used the right compressor start device and wired it per the original one.
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Whirlpool Refrigerator WSF26C2EXY02 (Refrigerator & Freezer Repair)
by DLanier 12/4/2023 5:06:34 AM(UTC)
Whirlpool Refrigerator Issue (Refrigerator & Freezer Repair)
by jrbentley 11/5/2023 1:04:02 PM(UTC)
Whirlpool Refrigerator Model WSF26C2EXF01 not making ice. (Refrigerator & Freezer Repair)
by agarcia5 8/26/2023 4:53:02 PM(UTC)
Whirlpool Refrigerator Model ED25TEXHW01 (Refrigerator & Freezer Repair)
by jammer48 8/18/2023 1:05:09 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
Whirlpool Refrigerator making a rather odd noise (Refrigerator & Freezer Repair)
by dbdata 12/7/2022 9:55:57 AM(UTC)
Whirlpool refrigerator water dispensing issue (Refrigerator & Freezer Repair)
by andymayor 7/6/2022 2:22:17 PM(UTC)
Whirlpool refrigerator replacement ice maker (Refrigerator & Freezer Repair)
by MELLIOTT 6/9/2022 9:06:52 AM(UTC)
Whirlpool refrigerator Model Number et1mtkxkq07 (Refrigerator & Freezer Repair)
by Guest 5/13/2022 1:16:28 AM(UTC)
Whirlpool refrigerator won’t freeze (Refrigerator & Freezer Repair)
by Nick72 5/12/2022 7:37:51 AM(UTC)
Whirlpool Refrigerator GD5SHAXLQ02 - Door not dispensing ice (Refrigerator & Freezer Repair)
by z-vap 3/21/2022 5:33:58 AM(UTC)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
Belarus aarrington 2/25/2022 5:39:48 AM(UTC)
