Gary1950
#1 Posted : Monday, April 29, 2013 2:49:53 PM(UTC)
Gary1950
Wife went into start dryer, loaded, set dial setting for specific drying time and pushed start - nothing. You can hear the timer running but, nothing starts.
Gary1950
#2 Posted : Monday, April 29, 2013 2:52:50 PM(UTC)
Gary1950
Can I assume is might be the push start button that has gone bad?
#3 Posted : Tuesday, April 30, 2013 6:07:09 AM(UTC)
Parts for Maytag MED5620TQ0 Dryer - AppliancePartsPros.com
See the attachment for the tech sheet
[COLOR="Blue"]
Can I assume is might be the push start button that has gone bad?[/COLOR]
No.
It could be a number of things.
Does the drum light work?
If not you may have lost Neutral.
The timer and heater on this unit run off of 240 volts.
The drum light and motor require 120 volts.
Also at the top of the list is a blown thermal fuse.
There seems to be a inconsistency between the parts breakdown and the wiring diagram. The wiring diagram shows a thermal fuse in the motor circuit but I cannot find it in the parts breakdown.
If it has one it is usually mounted on the blower assembly with the main control thermostat.
File Attachment(s):
MED5620.pdf (156kb) downloaded 6 time(s).
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
