My refrigerator stops cooling (frozen food starts to defrost, light is on but no fan or compressor running).
If I unplug the unit for a minute or two and plug it back in, everything comes back on and runs fine for a few days.
Whirlpool Model ET1MTKXKT01 Serial EL4528863
Any thoughts?
Thanks in advance, Dan
Here are your parts Parts for Whirlpool ET1MTKXKT01 Refrigerator - AppliancePartsPros.comSince unplugging it, resets it. It sounds like an electronic problem and this points to the adaptive defrost control board (item 4 in the Liner Parts section) re: it is getting stuck in a defrost cycle. To raise the odds of it being this part try turning the temperature control up/down a bit. Do not turn it off. If it fires up then it could the the control thermostat. If it does nothing then odds are higher that it is the defrost board. |
THIS FORUM IS DEAD!!!!!!! |
Any harm in putting it on a timer to shut off for 15 min each day so I don't lose anything in the freezer until I replace the control unit?
Thx, Dan
[COLOR="Blue"]Any harm in putting it on a timer to shut off for 15 min each day so I don't lose anything in the freezer until I replace the control unit?[/COLOR] I am not sure if this will stop the defrost cycle from running. But even if it does the evaporator coils will freeze over and cause problems. |
