eddins1968
#1 Posted : Wednesday, April 24, 2013 3:14:56 PM(UTC)
eddins1968
My Frigidaire dishwasher shuts down after about 10 minutes.When i open it up it has water in the bottom of it.I have changed the control panel and it does the same thing.I dont want to buy more parts until i get some advice .Any help would be apreciated.
#2 Posted : Thursday, April 25, 2013 3:12:37 AM(UTC)
See the attachment for your tech sheet.
Could be a problem with the heater re: the unit is waiting for the water temperature to reach a certain set point.
Unplug/remove power from the unit,
Check the hi-limit thermostat with a meter. Should be 0 ohms.
Check the heater resistance, should be about 20 ohms.
Check the wires from the control board to the heater/thermostat combo.
It is a good idea to remove at least one wire from any device you are checking for resistance. this ensures that you are not reading an alternate/parallel circuit path.
File Attachment(s):
FDB1050.pdf (576kb) downloaded 10 time(s).
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Frigidaire dishwasher fills and drains does not wash (Dishwasher Repair)
by Guest 9/19/2023 12:06:34 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
I20 error on brand new Frigidaire dishwasher (Dishwasher Repair)
by Guest 2/8/2023 6:50:55 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire dishwasher Model # LFID2422RF4B (Dishwasher Repair)
by lharwerth 11/22/2021 7:15:45 AM(UTC)
Frigidaire dishwasher ffbd2406nb3a no cleaning the dishes (Dishwasher Repair)
by Yolando 4/6/2021 5:50:57 PM(UTC)
Frigidaire Dishwasher ffbd2411ns1a Noise (Dishwasher Repair)
by bdwashburn 8/3/2020 11:11:43 AM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Frigidaire Dishwasher FDB1250REC0 no lights (Dishwasher Repair)
by Idesignedit 9/2/2019 9:37:32 AM(UTC)
Frigidaire Dishwasher FFBD2406NB0A (Dishwasher Repair)
by Brian P Mark 4/18/2019 4:54:21 AM(UTC)
Frigidaire Dishwasher LGID2475QF5A i20 error code (Dishwasher Repair)
by 210matt 11/4/2018 3:32:21 PM(UTC)
Frigidaire Dishwasher Soap Still Remains (Dishwasher Repair)
by Kryptonite 4/5/2018 12:21:21 PM(UTC)
*plz Help* Frigidaire Dishwasher Top Sprayer Will Not Work *plz Help* (Dishwasher Repair)
by Timma9705 2/21/2018 8:14:48 AM(UTC)
