korean1
#1 Posted : Monday, April 22, 2013 1:33:32 PM(UTC)
korean1
Ran cleaning cycle. After that both elements not working. Checked both with meter. Still getting continuity. So sensor or thermostat. Both read open contacts. Are both NO or etc.
On website the thermostat is no longer available.
Control board works fine.
scott5495
#2 Posted : Monday, April 22, 2013 2:18:25 PM(UTC)
scott5495
unplug your thermistor and test. it should read between 1000- 1100 ohms
or very close to these numbers. if it reads open it is bad. since it happened after you cleaned it, this sounds like the likely problem. some ovens have a resetable safety thermostat. if you have it, check the wiring diagram.
#3 Posted : Tuesday, April 23, 2013 2:33:12 AM(UTC)
Parts for Whirlpool RMC305PDQ2 Wall Oven - AppliancePartsPros.com
See the attachment for the tech sheet
Odds are that the thermostat (thermal cut-off) (item 37 in the Oven Parts section) has blown.
Could be that you have lost the 240 volts so you may want to check it.
As scott5495 said it is also a good idea to check the oven sensor to make sure it is within spec.
If the thermal cut-off is blown once it is replaced check the actual oven temperature at around 400 degrees just in case the oven is running hot and needs recalibration.
File Attachment(s):
RMC305.pdf (768kb) downloaded 2 time(s).
korean1
#4 Posted : Tuesday, April 23, 2013 5:39:08 AM(UTC)
korean1
thanks for the replies. Lets say that its the thermostat. Now the problem of getting the part that is not available.
Suggestions?
EDIT: ok just ohm'd the Thermostat. Completely open. Sensor readd 1.09ohms. So probably good.
So again...sounds like i might just be in to buing a new oven all together? Unless i can find this part...
scott5495
#5 Posted : Tuesday, April 23, 2013 2:42:53 PM(UTC)
scott5495
check the thermo for a temp, such as L200. may be able to match one up
#6 Posted : Wednesday, April 24, 2013 2:52:26 AM(UTC)
Here is the thermostat
Part number: AP2929236
The L135C on it means that it blows at 135 degrees C or 2785 degrees F.
You could take it to a local parts supply house and they may be able to find one for you.
Also you could go to AppliancePartsPros.
Then enter the Range/Cooktop/Oven section and search for thermostat.
then search through the results to find one that is a close match to yours.
Upper elements not working - Whirlpool GBD307PDB5 (Oven Repair (including Ranges and Cooktops))
by houtxfdcapt 8/6/2023 2:19:45 PM(UTC)
Amana AER6303MFB2 stove elements not working correctly (Oven Repair (including Ranges and Cooktops))
by r_pnw 6/16/2022 12:09:07 PM(UTC)
Frigidaire oven - bake and broil elements not working (Oven Repair (including Ranges and Cooktops))
by wife2004 9/21/2015 5:51:02 PM(UTC)
oven elements not working (Oven Repair (including Ranges and Cooktops))
by giroux68 12/6/2014 11:43:55 AM(UTC)
by chugalug 3/11/2014 12:27:15 PM(UTC)
Kitchenaid bake and convection elements not working (Oven Repair (including Ranges and Cooktops))
by ColdOven 11/26/2013 9:58:20 PM(UTC)
fisher paykel double oven top oven and broiler elements not working (Oven Repair (including Ranges and Cooktops))
by milo77 11/15/2013 9:17:53 AM(UTC)
One of the Two Broiler Elements Not working Kitchenaid KEM378s (Oven Repair (including Ranges and Cooktops))
by alfalover 3/1/2013 4:13:06 PM(UTC)
Heating Elements Not Working (Dryer Repair)
by Luketuomenoksa 7/21/2012 6:51:49 PM(UTC)
Heating Elements Not Working (Oven Repair (including Ranges and Cooktops))
by brooksb 5/1/2012 9:11:54 AM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
both elements not working (Oven Repair (including Ranges and Cooktops))
by dodalu 1/9/2011 12:50:26 PM(UTC)
Bake and Broil heat elements not working (Oven Repair (including Ranges and Cooktops))
by spiriteenie 4/30/2010 11:20:46 AM(UTC)
Elements not working after running self-clean (Oven Repair (including Ranges and Cooktops))
by lusien 4/6/2010 10:59:23 AM(UTC)
Oven bake or broil elements not working (Oven Repair (including Ranges and Cooktops))
by reginald jones 11/4/2009 8:06:59 AM(UTC)
