heppster
#1 Posted : Monday, April 20, 2009 11:31:59 AM(UTC)
heppster
Washer will not agitate or spin at all. It will fill and drain properly.
#2 Posted : Monday, April 20, 2009 2:00:58 PM(UTC)
Does the motor run?
heppster
#3 Posted : Monday, April 20, 2009 2:47:45 PM(UTC)
heppster
When I took the frontpanel off the machine, the motot had been replaced before, there was a relay setup and capacitor. I had already filled the tub with water and started to probe the harness when the motor started. The harness assembly had a broken wire on the capacitor, dual wire side. After repair I ran a complete cycle without a problem. This assembly was an upgrade by GE when they replaced the motor, as noted on the interior tub above motor.
Thanks for your help and concern. :)
#4 Posted : Monday, April 20, 2009 7:56:29 PM(UTC)
You are welcome. I'm glad you were able to fix it.
jazzierosalind@yahoo.com
#5 Posted : Saturday, April 25, 2009 10:12:58 PM(UTC)
My washer E G HAD A BURNING SMELL NOW IT WILL NOT AGITATE.
#6 Posted : Sunday, April 26, 2009 10:25:46 AM(UTC)
In order to provide most accurate advice we need the complete model number of the washer.
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
GE washer GTW750CPL0DG (Washer Repair)
by Guest 1/28/2024 11:49:12 AM(UTC)
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 12/19/2023 5:44:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 8/29/2023 7:01:15 PM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 3/27/2023 6:00:43 AM(UTC)
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2/14/2023 10:39:58 AM(UTC)
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
by Guest 2/12/2023 5:04:03 PM(UTC)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2/8/2023 10:36:12 AM(UTC)
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2/6/2023 5:37:03 PM(UTC)
GE washer wbse4220aoww (Washer Repair)
by Guest 9/21/2022 2:04:51 PM(UTC)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 9/19/2022 9:36:54 AM(UTC)
