We get a pf code and then intermittent it will give a number indicating how ling the cycle will run for..but does not start..we have changed the circuit box since we were unsure if this was the same problem to our water heater, which fixed the water problem..we held in start button for 5 seconds and no change..we also have changed the thermister with no luck in getting it to run...no blockages in vent either...please help, cannot afford a tech to come out!!!
Hello, Remove the toe panel and check the belt and the broken belt switch (under the idler pulley). - The belt Part number: 661570
Thxs Gene, the belt appears ok as well. Any other suggestions??
Sorry for the delay. Remove the top cover to access the main control board (#57 at the diagram). Check for 120 VAC between the wires connected to the terminals P1-2 & P1-5 at the control board. If the reading is correct, close the door ans check for 120 VAC between the wires connected to the terminals P1-5 & P1-3. If the reading is correct, set the dry cycle, push the start button and check for 120 VAC between the wire connected to the terminal P1-2 and the terminal P1-4 at the control board. If the reading is incorrect, replace the control board. - The control board Part number: 8546219
