st smith
#1 Posted : Monday, April 1, 2013 7:11:12 AM(UTC)
st smith
been following the other posts on this subject with related machines but can't find where to go next. my led on the circuit board is blinking green about 5-6 times every 6 seconds. I've tested the fuse and it's good. when i checked continuity across the red-red/white posts on the motor itself there was no continuity. do i have a bad motor?
fairbank56
#2 Posted : Monday, April 1, 2013 7:30:01 AM(UTC)
fairbank56
Groups: Expert
The blinking LED means you have power to the washer (fuse is good). With washer unplugged, lid closed, check continuity between hot (small blade) of the power cord and the orange wire (may be gray on some models) of the inverter leftmost connector. This checks the lid switch. Place washer in normal cycle, spin position, timer on, washer unplugged. Check continuity between hot of power cord and red wire of rightmost connector as well as to the blue wire of same connector. This checks timer contacts and wiring. If all good, motor/inverter is likey bad. Place timer in off position, plug washer back in, open/close lid 6 times within 12 seconds to reset inverter. Try spin again. If you get the same fault code, motor/inverter bad.
Eric
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Newer GE Washer will not agitate or spin (Washer Repair)
by dwolfe 9/11/2012 8:34:44 AM(UTC)
GE Washer Will Not Agitate Or Spin (Washer Repair)
by 35mastr 12/10/2010 9:36:56 AM(UTC)
Ge washer will not agitate or spin (Washer Repair)
by nanabell1225 10/3/2009 9:16:39 AM(UTC)
GE washer will not agitate or spin (Washer Repair)
by jkenshalo 8/22/2009 7:15:04 PM(UTC)
GE washer will not agitate or spin. (Washer Repair)
by BuckingDan 8/6/2009 4:49:14 AM(UTC)
