spidey52
#1 Posted : Thursday, March 21, 2013 7:57:34 PM(UTC)
spidey52
I have checked the thermal fuse, door switch, and start button with continuity meter and all are good. I've also ran 120 volts to the motor and it works fine. Before I spend the $90.00 on the timer switch is there any way that it can be tested with an ohm meter? I'm working with a Roper mod. #RED4440VQ1
Thank you in advance for any help.....
#2 Posted : Friday, March 22, 2013 1:11:11 AM(UTC)
Parts for Roper RED4440VQ1 Dryer - AppliancePartsPros.com
Unplug the unit.
Unplug one side of C to B at the timer.
The timer should be set mid cycle of a timed dry with heat setting.
Measure across C to B at the timer, should be 0 ohms.
Be sure to use your meter's most sensitive scale and short it's leads together before starting to measure. This tell you if there is any zero offset in the meter.
If it measures OK, then reconnect the wire/s to the timer.
Attach and leave it there, one of your meter leads to L1 on the line cord.
Then work your way back through the motor circuit.
L1 at terminal, should be 0 ohms.
C and B at the timer should be 0 ohms
Both sides of the thermal fuse should be 0 ohms
Motor's 4M should be 0 ohms.
Motor's 5M should be a couple ohms (motor's windings).
W or W-R at start switch, a couple ohms.
BK on the start switch. Infinite ohms when open. A couple ohms when it is pushed.
NO on the door switch, a couple ohms when start switch is pushed.
COM on door switch a couple ohms when door is closed and start switch pressed.
Same applies to Neutral on the terminal strip and the line cord plug.
File Attachment(s):
RED4440.pdf (182kb) downloaded 27 time(s).
spidey52
#3 Posted : Friday, March 22, 2013 11:02:19 AM(UTC)
spidey52
Thanks for the repley denman,
Between C and B it's shows as an open. I took a wire and jumped from C to B, plugged it in and pushed the start button and the dryer runs. So I've order a new timer switch.
Thanks again for the help.
spidey52
#4 Posted : Friday, March 22, 2013 12:34:42 PM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
spidey52
#5 Posted : Wednesday, March 27, 2013 2:03:05 PM(UTC)
spidey52
Denman,
Just wanted to thank you again, I finally recieved the timer switch and installed it and the dryed is working great.
Keep up the great work,
spidey52
bigdog123
#6 Posted : Thursday, May 9, 2013 3:52:09 AM(UTC)
bigdog123
Hey guys thank you much. I had the same issue ran denmans troubleshooter and found my problem. Replaced Timer switch and whoolah! my dryer works and my wife is off my case.
Guest (6)
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
