TubeCarz
#1 Posted : Tuesday, March 26, 2013 7:01:17 AM(UTC)
TubeCarz
Hello, my name is Brandon and im having a problem with my GE dryer.. Last night it worked perfectly normal.. The next time we used it a few hours later it would not turn on.. Since then i have checked the breaker, tested the plug on the wall, i took the switch panel off the front of the dryer and tested the switches, i got a 120 reading on the switches.. I checked the continual output when i turned the start switch off and on and it also has power.. I have tried the dryer on many different settings and it doesnt work for any of them.. I called GE and all they could tell me was that one of my switch modules could be bad.. Do you have any ideas/suggestions??? i would greatly appreciate the help!!!
Thank you for your time!
Simon / APP Team
#2 Posted : Tuesday, March 26, 2013 2:50:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Brandon.
You need to check several things.
First - the belt, then the belt switch or idler spring switch ,located at the bottom in the left corner.
Then there is the thermal hi-limit thermostat, located on the right side top of the heating element housing with two brown wires.
Check the switch and the thermostat for continuity using the multimeter.
Here are the breakdown diagrams and Backsplash, Blower & Motor Assembly parts for GE DWSR483EB0WW - AppliancePartsPros.com
Post the results.
Simon.
TubeCarz
#3 Posted : Tuesday, March 26, 2013 7:23:34 PM(UTC)
TubeCarz
Simon,
Thank you for your responce to my son concerning our dryer. Last month it was the stove ... which Denman pointed us in the right direction. When it rain's it pour's as they say ... :eek:
We had replaced the drum guides about a year ago. Why it took that long to cut one of the ill routed door switch wire's in half , but that's what he traced the problem back to when he went to "jump" the switch .... :confused:
Thanks again, you guys are great !
Charlie ...
Simon / APP Team
#4 Posted : Wednesday, March 27, 2013 8:52:22 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest (5)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
