the burner light on the left side is on the burners are off. the indicater light never go off.:confused:
Hello, Unplug the range. Remove the rear control panel cover. Remove the wire from the L1 terminal on each of the left side switches and check for continuity between the L1 & P terminals on each switch. If it reads continuity, replace the switch. - The infinity switch for 6" burner Part number: 316436000
Originally Posted by: Gene Hello, Unplug the range. Remove the rear control panel cover. Remove the wire from the L1 terminal on each of the left side switches and check for continuity between the L1 & P terminals on each switch. If it reads continuity, replace the switch. - The infinity switch for 6" burner Part number: 316436000
