When burners or lit the clicking of the igniters continue. What would cause this? Would it be a single igniter, although seems intermittent too me, or a spark module?
Ron
Does it continue to click when any of the top burners are lit? Or is it just one buerner that does this? I'm not familiar with this model. Could it be possible that the knobs aren't turned past the ignition portion of the knob? Just a few questions for us to help you figure out what's going on with your unit. Nat
Seems to be any burner and is intermittent. As for as burner knob being turned pass igniter, they are.
Then my guess would be, that the infinant switches or the spark module are getting stuck on ignite. That is only my educated guess, as I said I'm not that familiar with your model. Thee are several posts on this site that tells you how to test components. Or call a local tech to check it if you aren't comfortable doing the tests yourself. Nat
