slick154
#1 Posted : Wednesday, March 20, 2013 11:28:42 AM(UTC)
slick154
Refrig. and freezer quit cooling, does blow cool air, but not cold enough. Refrig. about 48 degrees, freezer 40 degrees. I replaced the defrost timer, hasn't helped. This unit was worked on when it was less then a year old. It has a cap on the freon line, possibly repairman added freon. I checked the condenser coils, they are clean, no ice or frost. The freon line running into the condenser is covered in ice. Any help would be appreciated.
Simon / APP Team
#2 Posted : Wednesday, March 20, 2013 2:46:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What do you call "condenser"?
The evaporator coils are located in the freezer. The condenser coils are next to the compressor.
Did you open and check the evaporator coils?
Simon.
slick154
#3 Posted : Thursday, March 21, 2013 5:30:39 AM(UTC)
slick154
Sorry about that. It is the evaporator coils in the freezer that the line is froze up. I thawed it out and plugged refrig. back in. Within 1 hour the small line going to the evaporator coils was frosting up.
Simon / APP Team
#4 Posted : Thursday, March 21, 2013 9:56:46 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the evaporator cover and check the frost pattern on the coils. If it's only partially frosted or has an ice build up in one corner - there is a sealed system problem and you need a professional.
Simon.
refrigerator and freezer not cooling (Refrigerator & Freezer Repair)
by robertch1 10/13/2014 4:03:59 PM(UTC)
Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by RichF 7/13/2014 3:03:42 PM(UTC)
by marmitage 2/5/2014 5:03:44 PM(UTC)
Refrigerator and freezer not cooling (Refrigerator & Freezer Repair)
by denada777 1/23/2014 3:32:07 PM(UTC)
by JHubb 8/25/2013 11:00:04 AM(UTC)
Amana Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by gabyrink 3/17/2013 5:10:31 PM(UTC)
by pbburkeen 7/5/2012 4:23:47 PM(UTC)
Refrigerator and freezer not cooling after lightning storm (Refrigerator & Freezer Repair)
by Jcrooker 6/17/2012 1:56:56 PM(UTC)
by erniej 8/24/2011 9:04:04 AM(UTC)
refrigerator and freezer not cooling properly (Refrigerator & Freezer Repair)
by Gman60 4/13/2011 6:18:17 AM(UTC)
by bboud 12/9/2010 9:51:56 AM(UTC)
Magic Chef Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by telephoneman 7/15/2010 11:57:22 AM(UTC)
by karinarao 5/7/2010 2:15:33 PM(UTC)
by Esther Iwunna 12/14/2009 9:26:01 PM(UTC)
Refrigerator and freezer not cooling. (Refrigerator & Freezer Repair)
by smgodoy24 10/7/2009 5:11:01 AM(UTC)
