TracyCarlson
#1 Posted : Thursday, April 16, 2009 8:02:38 PM(UTC)
TracyCarlson
Won:mad: 't fill with water on wash cycle but will on the rinse cycle!
#2 Posted : Friday, April 17, 2009 4:08:14 AM(UTC)
Perhaps a Model Number may help someone help you
TracyCarlson
#3 Posted : Friday, April 17, 2009 7:10:46 AM(UTC)
TracyCarlson
Oh yeah, sorry. It is a Fridgidaire model #GLTF1670AS0 Thanks
#4 Posted : Friday, April 17, 2009 7:01:55 PM(UTC)
Here is the tech sheet
ftp://ftp.electrolux-na.com/Pr...DF/Webster/134458900.pdf
Looks like a complicated piece of gear.
First I would try a cold wash cycle just to check iof perhaps the hot valve is shot.
TracyCarlson
#5 Posted : Saturday, April 18, 2009 8:10:09 AM(UTC)
TracyCarlson
WOW! Your right the tech sheet is a bit complicated. Funny thing is that it just started working again. I am just a bit leary that it was just a sign of total breakdown for the near future. Thanks for the reply though.
#6 Posted : Saturday, April 18, 2009 2:13:57 PM(UTC)
When things go intermittent often it is a loose or bad connection someplace.
In your case something in the water valve control circuits or timer.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
