PM1DPRO
#1 Posted : Wednesday, December 26, 2012 7:42:53 PM(UTC)
PM1DPRO
Oven won't heat in BAKE or Broil. Clock works fine. Timer works fine.
Details:
Press BAKE - BAKE flashes
Use arrows to select temp - BAKE & ON stay lit, but temp reverts to 100
Oven shuts off after approximately 15 seconds
Press BROIL - BROIL flashes;
Use arrow to select HI or LO - BROIL & ON stay lit for approximately 15 seconds, then oven shuts off
I have cycled power to oven in an effort to reset, but this has not helped.
Any ideas if this is a control board or other component? High temp shutoff, etc.?
Thanks!
elanger52
#2 Posted : Thursday, December 27, 2012 6:37:22 AM(UTC)
elanger52
I have the exact problem with our GE range. Hope they post a reply soon.
PM1DPRO
#3 Posted : Thursday, January 3, 2013 6:30:11 PM(UTC)
PM1DPRO
Sending board in for repair
PM1DPRO
#4 Posted : Tuesday, February 19, 2013 8:21:18 AM(UTC)
PM1DPRO
I sent my control board in to ApplianceTimers.com. They were the least expensive repair solution I could find. The board has now been repaired and I have reinstalled it. Oven is working fine, now. I highly recommend ApplianceTimers.com for repair.
PM1DPRO
#5 Posted : Tuesday, February 19, 2013 8:23:57 AM(UTC)
PM1DPRO
GE oven won't heat past 170 or so (Oven Repair (including Ranges and Cooktops))
by INGRIDB 2/18/2013 12:16:16 PM(UTC)
Norge oven won't heat up (Oven Repair (including Ranges and Cooktops))
by Daniel M. 10/27/2009 10:40:49 AM(UTC)
GE Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by ggrek123 7/9/2009 6:29:42 PM(UTC)
GE oven won't heat (Oven Repair (including Ranges and Cooktops))
by Nitro40 6/8/2009 5:55:15 PM(UTC)
