Oven won't heat past about 170 or so. Broiler works fine. Replaced oven baking element...same problem. I can hear the thermostat clicking but it never achieves the higher temperatures.
Help!!!:confused:
Groups: APP Team
Hi. Please check the oven sensor resistance. At room temperature you should have about 1100ohm and if it checks OK - replace the control board. The sensor Part number: WB23T10002
