PM1DPRO
#1 Posted : 12 years ago
PM1DPRO
Oven won't heat in BAKE or Broil. Clock works fine. Timer works fine.
Details:
Press BAKE - BAKE flashes
Use arrows to select temp - BAKE & ON stay lit, but temp reverts to 100
Oven shuts off after approximately 15 seconds
Press BROIL - BROIL flashes;
Use arrow to select HI or LO - BROIL & ON stay lit for approximately 15 seconds, then oven shuts off
I have cycled power to oven in an effort to reset, but this has not helped.
Any ideas if this is a control board or other component? High temp shutoff, etc.?
Thanks!
elanger52
#2 Posted : 12 years ago
elanger52
I have the exact problem with our GE range. Hope they post a reply soon.
PM1DPRO
#3 Posted : 12 years ago
PM1DPRO
Sending board in for repair
PM1DPRO
#4 Posted : 12 years ago
PM1DPRO
I sent my control board in to ApplianceTimers.com. They were the least expensive repair solution I could find. The board has now been repaired and I have reinstalled it. Oven is working fine, now. I highly recommend ApplianceTimers.com for repair.
PM1DPRO
#5 Posted : 12 years ago
PM1DPRO
GE oven won't heat past 170 or so (Oven Repair (including Ranges and Cooktops))
by INGRIDB 12 years ago
Norge oven won't heat up (Oven Repair (including Ranges and Cooktops))
by Daniel M. 15 years ago
GE Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by ggrek123 16 years ago
GE oven won't heat (Oven Repair (including Ranges and Cooktops))
by Nitro40 16 years ago
