howardr57
#1 Posted : Monday, February 18, 2013 10:22:11 AM(UTC)
howardr57
the washer rotary start switch moves and i cane here it running but nothing happens when i turn the knob by hand the drum starts going and then stops i checked the pump mooter with a ohm miter and got a good rating
Simon / APP Team
#2 Posted : Monday, February 18, 2013 11:52:38 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Please explain clearly what is the problem with the washer.Be more detailed.
Simon.
Joe / APP Team
#3 Posted : Monday, February 18, 2013 12:30:20 PM(UTC)
Joe / APP Team
Originally Posted by: howardr57 Go to Quoted Post
the washer rotary start switch moves and i can hear it running but nothing happens when i turn the knob by hand the drum starts going and then stops I checked the pump motor with a ohm meter and got a good rating
Howard, With both the washer and the dryer having start and run issues, have you considered checking the power supply to both appliances ? You could have an issue in the wiring or breaker box, causing neither machine to start or run.
howardr57
#4 Posted : Monday, February 18, 2013 3:44:51 PM(UTC)
howardr57
when i start the washer it will fill up and drum will run but it will not go into spin cycle and the water will not pump out i put a miter to the pump and got a good reading even when i turn the knob to spin and drain nothing happens i took the drain hose and put it to the floor some water came out and then stoped
Simon / APP Team
#5 Posted : Tuesday, February 19, 2013 10:13:47 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the washer agitates?
Does the motor runs when washer is in the spin?
Check if there is 120VAC at the drain pump contacts when timer set for drain.
Simon.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
