Squelch
#1 Posted : Thursday, February 14, 2013 9:02:21 AM(UTC)
Squelch
First off, I would like to thank all of you who assist with troubleshooting. I have found a great deal of useful information on this site. I have used the search function, but was unable to come up with a fix for my dryer.
I have a Whirlpool Duet Dryer, Model GEW9250PW0, that will not start. The front panel lights up as normal. When I push the Start button, I get a beep, the Sensing Status light comes on, the timer starts counting down, but the motor does not start running. All of the following checks have passed:
- Door switch
- Thermal fuse resistance = 0
- Belt switch
- Checked the resistance on the motor
- Thermistor resistance = 0
- Thermal cutoff resistance = 0
- Verified incoming 240V power
- Ran the diagnostic test. All switches and lights operated normally.
The only indication that differed from the troubleshooting guide was that I did not get the OE indication when the door was opened. It did beep and the light went out, but I got a code of 6E instead of OE. I did a circuit test on the door switch with an continuity tester and it passed.
I was thinking it might be the control board, but I read that if the timer counts down, this usually isn't the problem.
I'm out of ideas, other than just ordering parts and replacing until something works.
Once again, I appreciate your time helping with this.
Sincerely,
Chuck
hov01
#2 Posted : Saturday, March 16, 2013 8:24:34 AM(UTC)
hov01
I have been trying to resolve the same problem. Were you able to find a solution?
Thanks, Mike
Squelch
#3 Posted : Saturday, March 16, 2013 12:18:07 PM(UTC)
Squelch
Thanks, Mike
Mike,
Yes, I found the solution to be a burnt circuit on the main circuit board. There was no indication of anything burnt initially, but following advice from another website, I pulled the circuit board out of it's holder and found a burnt spot on the back, right under the motor relay (or whatever it's called. Looks like a relay box, and says motor, but I'm sure it's not actually a relay). I bought part number 1060737 from a website called "repair ************" for $221.15. It was an easy, drop in fit and work like a dream. Here is a link to the part: http://www.********************...ol-Board/8546219/1060737
Hope this helps.
Chuck
lengerjp
#4 Posted : Tuesday, January 3, 2017 6:53:13 AM(UTC)
lengerjp
My GEW9250PW0 dryer would not start. Chuck's update of 03-16-2013 at 08:47 PM led me to the problem / Solution. Thanks Chuck. I removed the main control board from the plastic case that holds it. On the bottom of the circuit board I noticed a small burn spot on one connection. The connection was for the relay that clicks when the Start button (front of dryer) is pressed.
Instead of ordering a new board or relay, I cleaned and re-soldered the burnt connection. The dryer fired right up after that.
Thanks again Chuck. You saved me a ton of money. I was ready to put the dryer on Craigslist Free Stuff.
Jerry
Whirlpool Duet won't start cycle or unlock door (Washer Repair)
by nine 2/20/2015 2:50:58 PM(UTC)
Whirlpool Duet Won't Start (Washer Repair)
by jfinchum 6/6/2009 1:55:38 PM(UTC)
