nobull1466
#1 Posted : Monday, February 11, 2013 3:20:27 AM(UTC)
nobull1466
The door on my Bosch microwave rubs just a bit when I open it. If I pick up on it all is well. Is there an adjustment on the hinge to correct this? Do I have to take the outer cover off to get to it?
Thx:confused:
#2 Posted : Monday, February 11, 2013 1:43:52 PM(UTC)
Hello,
I do not think there are any adjustments available. You can determine if there are any by removing the outer case.
If the microwave is less than a year old, it should be covered under the warranty.
nobull1466
#3 Posted : Tuesday, February 12, 2013 9:20:14 AM(UTC)
nobull1466
Couldn't wait for tech any longer. After checking the assembly out, I tapped the edge of the cabinet inward, away from the bottom of the door. Everything works perfectly now. Thanks for the info.
#4 Posted : Tuesday, February 12, 2013 5:44:16 PM(UTC)
You are welcome. I'm glad to hear you found a way around.
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Kitchen Aid Combo Microwave Door Flops Open Even After Springs (Oven Repair (including Ranges and Cooktops))
by chrison600 11/19/2022 11:33:49 AM(UTC)
Microwave door issue (Microwave Repair)
by mdezrin 3/5/2022 7:50:10 AM(UTC)
DE94-02053C Microwave Door Assembly (Microwave Repair)
by caleb3po 8/7/2019 10:13:27 AM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
microwave door replacement (Microwave Repair)
by purcel34 3/3/2019 8:59:04 AM(UTC)
Whirlpool Microwave Door Error and flipped breaker when plugged in (Microwave Repair)
by ellie0704 2/9/2019 9:12:28 AM(UTC)
ge microwave door (Microwave Repair)
by david habenicht 10/29/2018 11:26:32 PM(UTC)
Remove LG microwave door (Microwave Repair)
by papajoe 10/19/2017 1:06:47 PM(UTC)
I have to push up on microwave door to make it operate. (Microwave Repair)
by RGH0625 1/10/2017 1:17:12 AM(UTC)
Whirlpool microwave door handle broke (Microwave Repair)
by troyw66 11/9/2016 6:32:52 AM(UTC)
Microwave Door Handle (Microwave Repair)
by Dante77 7/7/2015 3:28:27 PM(UTC)
Microwave door latch (Microwave Repair)
by why? 4/28/2015 2:05:31 PM(UTC)
Maytag Microwave Door (Microwave Repair)
by Thia 9/10/2014 6:58:08 AM(UTC)
