AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Micro Wave working but makes loud buzzing noise sometimes
I have a GE Space Maker XL 1800 which has recently started to make a loud humming/buzzing noise. The noise dose not happen all the time and the microwave is still working. I see that it could be the Magnetron, how so i trouble shoot?
Originally Posted by: mark kuhn  ...The noise dose not happen all the time... Does it happen all the time when you use the microwave with 100% power? If it does, then you don't need any troubleshooting. Just replace the magnetron. - The magnetron Part number: WB27X10017
Yes,it has been just heating stuff up. Has not acted up more than a few times, is it possible we're at the beginning stages?
Is this a complicated repair, where or how do I get to the mag., do I need any special tools?
You would not need any special tools but you will need to remove the microwave from the cabinet.
So far I would recommend not to do anything until it'll die completely.
Thank you, sounds like good advice. As of this date microwave still working!
Keep us posted. Good luck.
Microwave Repair
