mark kuhn
#1 Posted : Sunday, February 10, 2013 3:47:56 PM(UTC)
mark kuhn
I have a GE Space Maker XL 1800 which has recently started to make a loud humming/buzzing noise. The noise dose not happen all the time and the microwave is still working. I see that it could be the Magnetron, how so i trouble shoot?
#2 Posted : Monday, February 11, 2013 1:02:14 PM(UTC)
Originally Posted by: mark kuhn Go to Quoted Post
...The noise dose not happen all the time...
Does it happen all the time when you use the microwave with 100% power?
If it does, then you don't need any troubleshooting. Just replace the magnetron.
- The magnetron Part number: WB27X10017
Here are the breakdown diagrams and Parts for GE JVM1861SD002 Microwave - AppliancePartsPros.com
mark kuhn
#3 Posted : Monday, February 11, 2013 1:31:55 PM(UTC)
mark kuhn
Yes,it has been just heating stuff up. Has not acted up more than a few times, is it possible we're at the beginning stages?
Is this a complicated repair, where or how do I get to the mag., do I need any special tools?
#4 Posted : Monday, February 11, 2013 3:42:01 PM(UTC)
You would not need any special tools but you will need to remove the microwave from the cabinet.
So far I would recommend not to do anything until it'll die completely.
mark kuhn
#5 Posted : Friday, February 15, 2013 10:54:44 AM(UTC)
mark kuhn
Thank you, sounds like good advice. As of this date microwave still working!
#6 Posted : Friday, February 15, 2013 4:06:19 PM(UTC)
Keep us posted. Good luck.
