flynkites
#1 Posted : Monday, February 4, 2013 6:28:06 AM(UTC)
flynkites
Microwave just stopped heating food but seems to be operating otherwise. Fan , light, turntable, light all work. All components (magnatron, transformer, capacitor, diode, and fuse) check out with ohmmeter. It has a distinct electrical burning smell when operated. I just examined this closely while operating and notice a distinct stream of smoke emanating from a small hole in the magnatron case adjacent to the connector.
What is this telling me? Has the magnatron failed? Has something else failed causing this problem?
flynkites
#2 Posted : Monday, February 4, 2013 7:21:18 AM(UTC)
flynkites
Instructions on Tech Sheet in oven say a good diode should check "infinite" in both directions with ohmmeter on Rx1000. The instruction sheets provided by Simon to another Posting say diode test should indicate "continuity" in one direction and "infinite" in the other. Which is correct? :confused:
Simon / APP Team
#3 Posted : Monday, February 4, 2013 12:51:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check out this post http://forum.appliancepartspros...19868-diode-testing.html
To check the diod for continuity your meter should be set for at least 100K ohm.
Sounds like you have a bad magnetron
Part number: 53001044
Here are the breakdown diagram and 05-Internal Controls parts for Maytag MMV5156AAQ - AppliancePartsPros.com
Post the results.
Simon.
flynkites
#4 Posted : Monday, February 4, 2013 6:56:44 PM(UTC)
flynkites
Can I replace the magnatron from the front, i.e. without removing the microwave from the wall and disassembling the case?
Simon / APP Team
#5 Posted : Tuesday, February 5, 2013 8:41:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unfortunately you will have to remove it from the wall.
Simon.
Guest (5)
Microwave does not Heat Food (Microwave Repair)
by newatappliancerepair 11/10/2016 10:53:37 AM(UTC)
Microwave does not heat...buzzing sound (Microwave Repair)
by bnhmiles 3/15/2012 3:33:46 PM(UTC)
Whirlpool Microwave Does Not Heat (Microwave Repair)
by FixItManTim 7/17/2011 9:06:24 PM(UTC)
microwave does not heat (Microwave Repair)
by suzzan 4/30/2011 2:42:48 PM(UTC)
GE Profile Microwave does not heat any more (Microwave Repair)
by dealmaster 10/13/2010 3:21:06 PM(UTC)
my microwave does not heat (Microwave Repair)
by videomandw 8/16/2010 6:37:53 AM(UTC)
ge microwave does not heat, everything else works (Microwave Repair)
by shaunshaw 4/7/2010 10:36:03 AM(UTC)
Microwave does not heat (Microwave Repair)
by Alex1977 11/15/2009 10:23:07 AM(UTC)
Kenmore microwave does not heat (Microwave Repair)
by srikki9 9/7/2009 11:15:49 AM(UTC)
Microwave does not heat up. (Microwave Repair)
by Aliens1 5/27/2009 9:32:29 PM(UTC)
microwave does not heat, smells like its burning and buzzes (Microwave Repair)
by doogie48084 5/26/2009 10:58:40 AM(UTC)
by blackbeard1298 4/30/2009 4:50:12 PM(UTC)
Jenn Air Microwave does not heat (Microwave Repair)
by SpacemonkeyR 4/23/2009 5:52:19 PM(UTC)
by Kerryi 3/19/2008 1:46:51 PM(UTC)
by Bob Shuler 10/29/2007 7:55:21 AM(UTC)
