lacoppari
#1 Posted : Wednesday, January 23, 2013 8:13:22 AM(UTC)
lacoppari
For the past 15 years our dishwasher will not start unless the selector button for pots/pans is the one engaged. The other two washes are normal and china. I know the normal button does nothing. The rinse-hold button works properly.
When you press the normal button, the timer runs and you an hear the click as the cycles are indexed by the timer. The washer works fine if the pots/pans button is pressed. I cannot say anything about the china cycle as it is never used.
What do you think needs replacing? The big switch behind all the buttons for pots/pans, normal, china, heated drying, rinse hold, etc.
Any help would be appreciated. Thanks in advance.
A few minutes later: I was going by memory here but was running a test as I typed above. I had engaged the normal button. Nothing happened until the timer button got to china, then the dishwasher began filling. The timer was originally at the pots/pans location. It passed by the normal index position where the washer should have started making only an easily audible click. When it got to the china position it began the fill process. But it should have started at the normal position.
Simon / APP Team
#2 Posted : Wednesday, January 23, 2013 12:09:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The key parts for this dishwasher is no longer available.
Sorry.
Simon.
lacoppari
#3 Posted : Thursday, January 24, 2013 3:00:01 AM(UTC)
lacoppari
But what is the problem? The switch or the timer?
But what about this?
http://www.********.com/itm/NEW...RT-4163547-/300565410339
lacoppari
#4 Posted : Thursday, January 24, 2013 3:01:49 AM(UTC)
lacoppari
But is it the timer or the switch that is the problem? I'm hoping someone can tell me so I don't have to go inside and investigate with a multimeter.
And what about this?
If you google the part number, you can find it on ********.
Bosch dishwasher does not start second cycle (Dishwasher Repair)
by Guest 3/2/2022 5:10:08 AM(UTC)
Bosch dishwasher does not start washing (Dishwasher Repair)
by brokedishwasher 4/3/2013 10:56:40 AM(UTC)
Kitchen Aid Dishwasher Does Not Start (Dishwasher Repair)
by eriewhaler 7/25/2011 5:42:29 PM(UTC)
Dishwasher does not start (Dishwasher Repair)
by rsabbag 12/3/2009 7:40:21 AM(UTC)
kitchenaid dishwasher does not start (Dishwasher Repair)
by daid schiffl 8/25/2009 3:44:26 PM(UTC)
KitchenAid Dishwasher does not Start (Dishwasher Repair)
by fra 7/27/2009 8:09:11 AM(UTC)
by Phillip Anderson 6/1/2009 12:52:06 PM(UTC)
by dwnhll 5/21/2009 11:43:42 AM(UTC)
by jmshareef 9/8/2008 10:03:47 PM(UTC)
