kellih
#1 Posted : 12 years ago
kellih
My Maytag gas oven was slow to light. I have replaced the igniter. It tests at 3.4 amps. I then replaced the safety valve. When you turn the oven on, the igniter comes on, after about 45 seconds there is a smell of gas. But it doesn't light for around 15 to 30 minutes. What next?
#2 Posted : 12 years ago
Hello,
Make sure the gas shut off valve is completely open.
Check the oven burner for a clogged holes.
Verify that the oven igniter is properly aligned.
Here are the breakdown diagrams and Parts for Maytag CWG3100AAS13 Wall Oven - AppliancePartsPros.com
