Washer not filling with water. Replaced fill valve, no change. :( The washer runs through all cycles if filled manually with water.
What else should I look at?
Thanks!!
Groups: APP Team
Hi. Open the control panel and check the lid switch assembly fuse. If it's blown - replace the lid switch assembly Part number: 22001682
Simon, the fuse was it! Thank You!!! A good lesson to remember the first thing to check for an electrical problem is any fuse.
Thanks Again! Peter
Groups: APP Team
You are most welcome.
Simon.
