2 Pages12>
neco187
#1 Posted: : Saturday, January 12, 2013 6:40:54 PM(UTC)
neco187
My washer won't start. I hit the button and nothing.
When I change the load selector the cycle times change.
Please help
fairbank56
#2 Posted : Sunday, January 13, 2013 6:22:58 AM(UTC)
fairbank56
Groups: Expert
Check the water level pressure switch behind the control panel. This is a normally closed switch. You should have continuity across the two terminals with the wires removed.
Eric
neco187
#3 Posted : Sunday, January 13, 2013 8:16:11 AM(UTC)
neco187
I'll try that.what if there is, then what?
fairbank56
#4 Posted : Sunday, January 13, 2013 9:19:58 AM(UTC)
fairbank56
Groups: Expert
I am assuming that when you say your washer will not start, that it does not fill. Is this correct?
Eric
neco187
#5 Posted : Sunday, January 13, 2013 10:03:35 AM(UTC)
neco187
Yes sir. I hit the start button, nothing. If I change cycles the time changes but nothing else.
fairbank56
#6 Posted : Sunday, January 13, 2013 10:35:46 AM(UTC)
fairbank56
Groups: Expert
Try a reset by unplugging the washer for 2 minutes. When you plug it back in, does the display come on right away or do you have to press the start button for it to come on?
Try going into service mode by pressing and holding the start button and rotate the cycle selector 180 degrees (8 clicks). Release start button and display should show 88 and all 3 LED indicators should be on. Rotate 2 clicks to the right to check for error codes. Error codes are indicated by any of the 3 LED indicators being on. If on, note which ones. Rotate one more click to the right to check for further error codes and note them. Each successive click after that will activate the hot water valve, cold water valve, slow agitate, fast agitate, pump, and spin. To exit service mode, press/hold start button and rotate cycle knob 180 degrees, release start button.
Eric
neco187
#7 Posted : Sunday, January 13, 2013 10:54:33 AM(UTC)
neco187
When I hit the start button nothing happens. The display doesn't turn on til I change the cycles
neco187
#8 Posted : Sunday, January 13, 2013 11:07:55 AM(UTC)
neco187
I can't get into service mode. Is it possible the start button took a shit and the board is bad
fairbank56
#9 Posted : Sunday, January 13, 2013 12:27:14 PM(UTC)
fairbank56
Groups: Expert
That's what it looks like. If you get the board from here and it doesn't fix the problem, you can return it.
Eric
neco187
#10 Posted : Sunday, January 13, 2013 12:58:04 PM(UTC)
neco187
I had continuity on the switch. I had to wait for a meter.
I also have no blinking light on top of the motor. I took off panel to look for it and I don't even see a light.
Guest (4)
GE Washer will not start (Washer Repair)
by Seapro210 5/5/2009 4:33:24 PM(UTC)
2 Pages12>
