i24jgb
#1 Posted : Sunday, January 6, 2013 6:22:43 AM(UTC)
i24jgb
Child Safe mode will not release. Replace control panel? Or is there somthing I am over looking?
#2 Posted : Sunday, January 6, 2013 8:56:34 AM(UTC)
Have you tried unplugging/remove power from the unit for a couple minutes to see if it will reset?
i24jgb
#3 Posted : Sunday, January 6, 2013 9:24:00 AM(UTC)
i24jgb
Yes, no change
#4 Posted : Monday, January 7, 2013 12:34:45 AM(UTC)
Parts for Whirlpool KUDS25SHWH1 Dishwasher - AppliancePartsPros.com
Unforetunately it does not give a pin-out for the keypad.
The problem will be either with the keypad or the control board.
If the lock light is flashing I would try the keypad first as this could be a stuck key problem.
If it is on solid I would replace the control board.
Either one is a bit of a gamble.
File Attachment(s):
KUDS25.pdf (484kb) downloaded 2 time(s).
i24jgb
#5 Posted : Tuesday, January 8, 2013 4:05:05 AM(UTC)
i24jgb
Light does flash, but i don't see a separate part for the pad only control assy. My unit is white and the only one I see available is black! If it is a stuck key and can be freed.That would be nice.
Thanks denman
#6 Posted : Tuesday, January 8, 2013 4:44:50 AM(UTC)
Give the parts people a call they have more info than I do.
There are a number of versions of the control panel listed but they are all just black. They should be for the different colors so it may just be a problem with this data set..
Always a possibility that the other colors are no longer available, only the parts specialists will know.
Unsticking a key is very iffy.
Thy are usually bubble type keys.
There is a possibility that if you remove the panel and put it in a freezer overnight that the thermal contraction caused by freezing it will pop it back up.
I used to use a product called FreezeIt re: a freezing spray, to just freeze the one key area. This may mess up the plastic protective cover.
Works maybe 1 in 10 times.
Control panel has no error but status shows sensing mode light ON (Dryer Repair)
by Neil74 4/28/2024 6:56:25 AM(UTC)
Subzero 650 Control Panel (Refrigerator & Freezer Repair)
by kbf99 2/14/2024 5:06:04 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Control panel for GE Spectra Stove Model # JBP79WB4WW (Appliance Parts)
by janieben@rainbowtel.net 1/22/2024 5:16:12 PM(UTC)
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Dispenser control panel is dead (Refrigerator & Freezer Repair)
by Expat 1/21/2023 1:56:42 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Whirlpool WRF555SDHV refrigerator dispenser control panel (Refrigerator & Freezer Repair)
by janinePR 12/8/2022 2:17:23 PM(UTC)
GE GSS25WGTGBB - Control panel dies when turning on dispenser light (Refrigerator & Freezer Repair)
by noparts 9/19/2022 6:17:40 AM(UTC)
Maytag MHWE300VW00 Control Panel shuts off, then on, then off... (Washer Repair)
by ab2112 8/1/2022 10:00:14 AM(UTC)
