AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Install Door Lock Assembly For Frigidaire Front Loader Washer Model#gltf2940es3
I need help for installing a door lock assembly for Frigidaire washer model #GLTF2940ES. I bought the part from the website but don't know how to install. Please respond. Thank you.
The instructions are attached to the reply. Good luck. Gene.
Thank you for the instructions. My husband and I will use them this weekend. Bye
Originally Posted by: Gene  The instructions are attached to the reply. Good luck.
Gene. Thanks,Gene--Searched for this thread for a week--and 3 days for switch to arrive--10 min. labor no problems. Your obvious expertise has been greatly appreciated.
Originally Posted by: plineman  Thanks,Gene--Searched for this thread for a week--and 3 days for switch to arrive--10 min. labor no problems. Your obvious expertise has been greatly appreciated. You are welcome. We are glad you were able to fix it. Good luck with your washer. Gene.
I Had the EXACT same issue....apparently Very common with this model.
Part is on the way!
On a side note, a repair tech came out and told me it was the drain pump....$350 for the part and labor. The pump is $50, and the labor looks simple. This guy gives repairmen a bad name.....
hi, my washer machine wont spin at end of cycle. Ive read its either door latch or motor board. Is there a way to find out which one without multi-meter test? If its the door latch can you send instructions? Bodie
Perform the Diagnostic test as described in the Tech sheet and post the results. Post the end of the model number (one more digit). Gene.
I seem to having this same issue with our Frigidaire GLFT2940ES3.
BUT
I'm not getting any error codes of any kind.
The machine will run through an entire cycle...time runs perfectly normal...then when time for the spin comes up, suddenly the time display goes from whatever amount of time is displayed to zero, the machine signals that the cycle is finished, and the door unlocks, as if the spin actually happened.
Is it likely the same problem, the secondary door latch?
The Machine is 8 years old, and to be honest, I can't afford to nickel and dime parts.
Washer Repair
