DannyG
#1 Posted : Thursday, January 3, 2013 12:16:16 PM(UTC)
DannyG
I'm hopeing someone can point me to a tech sheet for troubleshooting my refigerator thats online someplace?
Near as I can tell that's what should have been located behind one of the panels. IDK but I have dont even have a wiring schematic. :(
Plus I was wondering if this could be a common issue for these refigerators?
problem: Most of the time the refigerator works great. (days/weeks) But once in while it will seem to just stop cooling for no reason (both parts) and I my food goes bad.
When that happens I still hear motors running but everything is warm and then somehow the problem seems to dissapear and everything starts working corectly again.
Dan
ps: I guessed at the age.
#2 Posted : Friday, January 4, 2013 2:42:40 AM(UTC)
You compressor may fail to start sometimes, just check it next time it fails. Could be a bad motherboard or a evaporator thermistor. If you have no meter, I would replace both items available on this parts site.
If the fan motors work, but not the compressor, I would suspect a blown solder connection in the back of the motherboard.
DannyG
#3 Posted : Friday, January 4, 2013 10:29:10 AM(UTC)
DannyG
Thank you for the tips. Especially the sticky post about evap motor bearings/main boards because I would have missed a problem like that for sure.
If possible I would really like to find the documentation for this thing before touching it because I'm a tech in the HVAC commercial/industrial field and just don't know appliances.
DannyG
#4 Posted : Friday, January 4, 2013 4:37:50 PM(UTC)
DannyG
Ptoblem solved.
Thanks again...
#5 Posted : Saturday, January 5, 2013 1:04:17 AM(UTC)
Your service sheet is usually behind the encoder panel.
Missing tech sheet and diagnostic guide (Washer Repair)
by jlp01 10/1/2012 4:45:43 PM(UTC)
Missing tech sheet (Refrigerator & Freezer Repair)
by Mike S 2/3/2008 11:09:28 PM(UTC)
