I've replaced pump (coin stuck - burned out pump motor) . 1 month later, getting ND code again. Pump is fine and no blockage in drain hose (to and from pump). I've taken back and top panels off - no tech sheet! I can't find a diagnostic guide for this model either (does it have one?).
THIS FORUM IS DEAD!!!!!!! |
