jlp01
#1 Posted : Monday, October 1, 2012 4:45:43 PM(UTC)
jlp01
I've replaced pump (coin stuck - burned out pump motor) . 1 month later, getting ND code again.
Pump is fine and no blockage in drain hose (to and from pump). I've taken back and top panels off - no tech sheet! I can't find a diagnostic guide for this model either (does it have one?).
#2 Posted : Tuesday, October 2, 2012 1:04:48 AM(UTC)
Replacement parts for Maytag NFW7200TW10 AUTOMATIC WASHER | AppliancePartsPros.com
File Attachment(s):
NFW7200.pdf (1,493kb) downloaded 16 time(s).
