I posted a thread about this same washer some time ago.Koolaide was spilled down front of control panel,so I ordered parts from appliance parts pros.Ordered controll panel softtouch,and a control board,not knowing which part actually was damaged.
I installed the control panel by itself first off,when it came in and wallah! dishwasher came right on,started filling,started washing,sounded great.This dishwasher has not been running for about 2 years,just wanted to note that.I let it run on the normal cycle for about 15min,then cancelled operation and it drains automatically when you cancel.
Then I put in some amonia,a soap pack in the dispencer,and some cascade in the bottom of tub,and turned unit back on,this time put on pot scrubber mode(since this runs for longer period)set it for high temp.and sanitizer selection,and let it run.Timer went from 96min. down to about 47min.,everything was sounding fine,heard the soap dispencer drop the soap pack ,and no leaks underneath. I would open door and check how it was looking inside,scrubbed a few dirty spots,and closed door,and unit started again automatically. Then all of a sudden,unit shut down,no lights, nothing. Pushed buttons on panel,nothing,pushed start,nothing.
Checked breaker,was not tripped. So I turned off breaker,took panel down,looked to see everything looked good,no burns or broken wires.Turned breaker back on,tested door switch,was good.Shut off power, took thermal fuse out,ohmed it,and it was bad.
After saying all this,my concern is this. Remember now,I still have not installed the new control board that i ordered,just controll panel. My question is,do you think if I order a fuse kit,and replace wires and fuse,will this eliminate the problem,or will i have to install the new board along with the fuse,since this may be whats causing the fuse to blow?
Note,also i have never used the hot setting,with sanitizer before the unit broke,so don't know if it was just because the fuse and wire to it,are the defective ones that i am hearing about,or its because of the board haveing been damaged when the front control panel got damaged.
Just thought I would see if you feel I should be checking any other parts before I run it for a long period again with the new fuse.
signed almost there thanks to appliance parts pros,but still frustrated.
