leland48
#1 Posted : Wednesday, April 15, 2009 7:32:25 AM(UTC)
leland48
I just received my order from APP.com.
1-#WD24X10018 Piston & Nut Assy.
1-#WD8X219 Valve Body Gasket.
I took the old piston & nut assy. out and can see the valve body gasket. My question is: Is that gasket replaceable from inside the washer, or do you have to do it from underneath?
#2 Posted : Wednesday, April 15, 2009 10:56:15 AM(UTC)
You do have to remove the dishwasher from the cabinet and remove the body valve. Why do you think this gasket has to be replaced? I never heard it brakes.
Here are the breakdown diagrams and Replacement parts for GE GSD5120D01BB | AppliancePartsPros.com
leland48
#3 Posted : Wednesday, April 15, 2009 11:31:47 AM(UTC)
leland48
That gasket looks like it has something to do with sealing around the piston body, so I pulled the old one out and tried to put the new one in from inside the washer. Needless to say, it wrinkled and when I turned the washer on, it sprayed water everywhere on the pump cycle. Live and learn. Wish I had waited for your reply. Already had it fixed when I saw it. I'm using the old gasket as the new one has a permanent wrinkle. Don't know why they offer this part. Don't think it could ever wear out.
Thanks again.
Jerry
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
ge dishwasher leaking at bottom (Dishwasher Repair)
by Jerry7235 10/31/2013 1:48:10 PM(UTC)
GE Dishwasher leaking at shaft near solenoid valve (Dishwasher Repair)
by e-man 8/14/2011 6:55:10 PM(UTC)
GE Dishwasher Leaking Out Through Water InFeed during aggitation (Dishwasher Repair)
by andrewmcc 3/26/2011 3:20:29 PM(UTC)
GE dishwasher leaking at bottom right front door (Dishwasher Repair)
by ZincWhiskers 3/23/2010 12:03:20 PM(UTC)
GE Dishwasher Leaking (Dishwasher Repair)
by katiedbell 11/29/2009 4:50:08 PM(UTC)
GE Dishwasher leaking (Dishwasher Repair)
by must9450 9/11/2009 1:27:16 PM(UTC)
by _Joe_ 8/6/2009 8:52:48 AM(UTC)
GE Dishwasher Leaking from fitting below washer arm (Dishwasher Repair)
by DeG6 11/25/2008 11:59:59 PM(UTC)
GE dishwasher leaking (Dishwasher Repair)
by Chuck Hamby 11/9/2008 10:33:16 AM(UTC)
