polishplumber
#1 Posted : Thursday, December 27, 2012 4:05:28 PM(UTC)
polishplumber
Hi. I Have A Stackable Maytag Unit. The Washer Stops After The Rinse Cycles. Im Assuming It Might Be The Control Panel. As Well The Bleach And Softener Dispensers Fill With Water And Dont Drain. Any Help Will Be Greatly Appreciated. Thank You
Simon / APP Team
#2 Posted : Thursday, December 27, 2012 4:49:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does it drain the water out?
Does the door locks?
Simon.
polishplumber
#3 Posted : Thursday, December 27, 2012 5:06:06 PM(UTC)
polishplumber
THANKS FOR THE QUICK REPLY. THE TUB STAYS FULL AND THE DOOR IS LOCKED WITH THE ON AND THE DOOR LOCK LIGHTS ON.
Simon / APP Team
#4 Posted : Thursday, December 27, 2012 5:33:32 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check the drain pump, drain hoses.
If the pump is getting 120VAC but is not draining and there is no restriction in the drain line - replace the pump.
Here are the breakdown diagrams and 01-Base (washer) parts for Maytag MLG2000AWW - AppliancePartsPros.com
Simon.
polishplumber
#5 Posted : Thursday, December 27, 2012 6:08:16 PM(UTC)
polishplumber
HI SIMON. AFTER THE UNIT SHUTS DOWN AND I PUSH THE START BUTTON IT DOES DRAIN AND GOES TO THE NEXT RINSE CYCLE AND THE STOPS AGAIN. IF I TURN THE KNOB TO RINSE 3 IT WILL CYCLE OUT AND PUMP OUT AND SPIN AND SHUT DOWN IN PROPER MODE. DOES THAT SAY ANYTHING. THANKS AGAIN, MUNISH.
Simon / APP Team
#6 Posted : Friday, December 28, 2012 10:46:23 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you chose the cold water wash will it fill up?
Simon
polishplumber
#7 Posted : Friday, December 28, 2012 3:17:13 PM(UTC)
polishplumber
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
HI SIMON, I JUST TRIED IT. YES IT DOES FILL ON THE COLD SETTING
polishplumber
#8 Posted : Saturday, January 5, 2013 9:42:57 AM(UTC)
polishplumber
HI.SIMON. GREAT NEWS.I TOOKYOUR ADVICE. I TOOKTHE HOT AND COLD WATER SUPPLIES OFF AT THE BACK OF THE WASHER. THE HOT SIDE WAS CLEAR. I TOOKTHE COLD OFF AND NEARLY FELL ON THE FLOOR.IT WAS COMPLETELY BLOCKED OFF WITH THIS BROWN MUCK SLINE CALCIUM OR WHAT EVER. I CLEANED THE PORT AND CYCLED THE MACHINE. IT RUNS PERFECTLY. LIKE NEW. YOU DID IT AGAIN. I THANK YOU VERY MUCH, I OWE YOU A BEER!!!!!!!!! HAVE A GREAT NEW YEAR!!!!:)
Simon / APP Team
#9 Posted : Saturday, January 5, 2013 9:49:15 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
kwinky2003
#10 Posted : Sunday, September 15, 2013 8:12:50 PM(UTC)
kwinky2003
Hello, my name is Ken
Im working on a Maytag Neptune MLG2000AWW.
The washing machine is the problem.
First of all the ON LIGHT wont come on altho the machine starts filling
The DOOR LOCK LIGHT does not come on.
If I keep the START button pushed in the machine continues to fill and agitate then drain but it will not spin. It does not pump out all the water in the tub but water is not visible in the tub, you can hear it slosh around when tub is rotated.
Ive tried replacing the TIMER, no luck.
Ive tried replacing the MOTOR CONTROL BOARD, no luck.
Does this machine have a PUMP FILTER?
Can the DOOR LATCH MECHANISM be checked.
Any help will be greatly appreciated.
Ken
Guest (7)
Washer stops between cycles (Washer Repair)
by 54591974 2/11/2013 7:04:07 AM(UTC)
washer stops between cycles (Washer Repair)
by ruthwilson 2/26/2011 10:37:29 AM(UTC)
