esmyth
#1 Posted : Thursday, December 6, 2007 5:22:59 AM(UTC)
esmyth
Found a large puddle in front of the machine and removed kick plates etc to check under machine. Ran rince cycle to check it and discovered dripping from around where the pump flange(?) meets tub. Is this a simple fix? The machine is included in the GE recall.
#2 Posted : Thursday, December 6, 2007 3:06:28 PM(UTC)
Most likely the problem is a broken seal inside the pump.
There are two ways to fix it.
(1) You can buy the impeller & seal kit and repair the old pump (it comes with the installation instructions)
or
(2) You can replace the pump & motor assembly.
In both cases the dishwasher has to be removed from the cabinet.
- The part number for the impeller & seal kit AP631386
- The part number for the pump & motor assembly AP2616850
- Here are the break down diagrams for the GE dishwasher Model GSD4030Z05WW
esmyth
#3 Posted : Thursday, December 6, 2007 5:27:39 PM(UTC)
esmyth
It looks like it's dribbling down from around the pump connect AP203942. any quick way to check this?
#4 Posted : Thursday, December 6, 2007 5:40:02 PM(UTC)
This number is incorrect.
esmyth
#5 Posted : Friday, December 7, 2007 3:36:20 AM(UTC)
esmyth
you are coorrect. The number I was looking at was AP2039426 or AP2039418. I'm going to look at the spray arm
esmyth
#6 Posted : Friday, December 7, 2007 5:07:52 AM(UTC)
esmyth
I dropped the motor and the pump connect has a hole in it. Looks like it was punctured from a sharp straw!
