gibby289
#1 Posted : Thursday, December 6, 2007 4:06:33 AM(UTC)
gibby289
Kenmore Gas Range. I can hear the clicking of the igniter and smell the gas but no ignition. I'm guessing it's the igniter but wanted a better opinion. This was interminent before. Recently did a self clean and now won't ignite at all. Also, if it is the ignitor is it in the back or under the spreader plate inside? Thanks so much!!
#2 Posted : Thursday, December 6, 2007 2:56:09 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the range.
ryant
#3 Posted : Tuesday, April 8, 2008 4:48:37 PM(UTC)
ryant
I need help to install an igniter burner into a Kenmore Gas Range model number 362.75980891. Is this something I can do? Many thanks.....:confused:
#4 Posted : Tuesday, April 8, 2008 7:17:19 PM(UTC)
Hi ryant,
Which igniter are you talking about: the bake burner, the broil burner or the top burner?
All igniters sparking (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/30/2024 11:43:18 AM(UTC)
Removing igniter from thermador star (Oven Repair (including Ranges and Cooktops))
by Guest 2/24/2024 9:17:28 AM(UTC)
Maytag Double OVen Model MGR6875ADW- Igniter wont stop ticking (Oven Repair (including Ranges and Cooktops))
by gnieciag 10/15/2023 1:53:42 PM(UTC)
gas igniter troubleshooting (Dryer Repair)
by siberian72 10/10/2023 3:40:20 AM(UTC)
DCS 6 burner range igniter issue (Oven Repair (including Ranges and Cooktops))
by Dcsovenrepairguy 7/1/2023 12:42:26 PM(UTC)
Electrolux Gas stove igniter (Oven Repair (including Ranges and Cooktops))
by Guest 2/10/2023 10:22:25 AM(UTC)
DCS RGT-366-N burner igniter clicking (Oven Repair (including Ranges and Cooktops))
by Guest 1/21/2023 7:22:13 PM(UTC)
Broiler igniter issue (Oven Repair (including Ranges and Cooktops))
by Nubthumb 7/20/2022 4:36:27 PM(UTC)
igniter does not glow (Dryer Repair)
by Smatt 11/27/2021 2:32:24 PM(UTC)
Whirlpool GW397LXUS06 - 1 igniter not working (Oven Repair (including Ranges and Cooktops))
by TommyBoy2323 2/14/2021 8:56:10 AM(UTC)
Jenn-Air JCG9536ADS gas cooktop igniter behavior (Oven Repair (including Ranges and Cooktops))
by tedshred 12/1/2020 2:50:11 PM(UTC)
Maytag - Igniter will not glow (Dryer Repair)
by swatosh 11/13/2019 7:39:01 PM(UTC)
BOSCH Vision 500 Gas (NG) Dryer Model #WTVC6530UC/11 - igniter won't light, rapid clicking sound (Dryer Repair)
by KenBradley 8/11/2019 7:30:53 PM(UTC)
SF395LEEB igniters on the right side do not work (Oven Repair (including Ranges and Cooktops))
by Joepre 7/28/2019 5:56:31 AM(UTC)
SF395LEEB igniter question (Oven Repair (including Ranges and Cooktops))
by Joepre 7/28/2019 5:54:30 AM(UTC)
