1sgret
#1 Posted : Thursday, December 13, 2012 4:27:31 PM(UTC)
1sgret
I have replaced thermal fuse and high limit thermostat twice, did three loads of clothes and went out again, checked vent and hose no blockages
dryer turns on but won't heat up
#2 Posted : Friday, December 14, 2012 9:55:19 AM(UTC)
Here is my standard blurb on this type of problem.
I am assuming that you have checked the fuse/thermal cut-off and are sure it is blown.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
Whirlpool dryer-thermal fuse keeps blowing (Dryer Repair)
by daddjdom 3/28/2017 9:44:13 AM(UTC)
Kenmore Dryer Thermal Fuse keeps blowing (Dryer Repair)
by zunah 2/23/2015 7:16:12 PM(UTC)
Thermal fuse keeps blowing (Dryer Repair)
by Tony Chapparo 10/5/2011 6:20:32 AM(UTC)
Roper thermal fuse keeps blowing (Dryer Repair)
by andrewprescott75 8/16/2011 4:45:24 PM(UTC)
Thermal fuse keeps blowing (Dishwasher Repair)
by bobgjr 6/24/2011 4:25:31 AM(UTC)
kenmore thermal fuse keeps blowing (Dishwasher Repair)
by kbay1977 1/23/2010 4:31:25 AM(UTC)
Dryer thermal fuse keeps blowing (Dryer Repair)
by pocketpet3500 8/19/2009 3:56:32 PM(UTC)
Thermal Fuse Keeps Blowing w/o venting obstruction. (Dryer Repair)
by bcourtland 5/18/2009 7:08:11 AM(UTC)
by needs help 4/13/2009 10:15:06 AM(UTC)
Thermal fuse keeps blowing, burning on wires and circuit board (Dishwasher Repair)
by _billc@pop.net 1/1/2009 10:11:49 AM(UTC)
Thermal Fuse keeps blowing (Dishwasher Repair)
by blackbadge 10/6/2008 5:04:27 AM(UTC)
