Stekelenburg
#1 Posted : Wednesday, December 12, 2012 9:55:44 AM(UTC)
Stekelenburg
I own a 42" counter depth French door Kitcen Aid refrigerator KBFO42FTX04. The icemaker (located in freezer drawer) stopped working. Turned the fridge off for 5 minutes, that didn't solve it. Freezer temp is 0 degrees. The red led blinks twice followed by a pause. Looks like nothing is obstructing the left side where the led is supposed to shine. Also installed a new water filter. Any guesses on what steps I should take next? Thanks for your help.
#2 Posted : Wednesday, December 12, 2012 5:40:37 PM(UTC)
Hello,
Make sure the ice maker on-off switch is on.
Press in the emitter flapper door to unblock the optic beam and observe the LED. Post the results.
Here are the breakdown diagrams and Parts for KitchenAid KBFO42FTX04 Refrigerator - AppliancePartsPros.com
Stekelenburg
#3 Posted : Thursday, December 13, 2012 4:07:26 AM(UTC)
Stekelenburg
Thanks for your assistance.
With the flapper depressed, the red led on the right-hand side continues to blink twice with about one second of a pause between blinks.
The icemaker on/off switch is in the "on" position and operates properly.
#4 Posted : Friday, December 14, 2012 7:34:51 PM(UTC)
Looks like the problem is a bad ice maker optics. The instructions are attached to the post.
- The divider (includes receiver board) Part number: W10290822
- The spacer (includes emitter board) Part number: W10321131
File Attachment(s):
Removing the ice maker optics - 1.doc (656kb) downloaded 27 time(s).
Removing the ice maker optics - 2.doc (588kb) downloaded 21 time(s).
Stekelenburg
#5 Posted : Monday, December 17, 2012 11:44:41 AM(UTC)
Stekelenburg
Thanks Gene,
I much appreciate your help with this. Before I order all these parts, can you tell me what the red led is supposed to do? How can one determine if the emitter or receiver are faulty? Or do both need to be replaced?
Are you confident that it isn't the icemaker unit?
Thanks again,
J.C.
#6 Posted : Monday, December 17, 2012 12:04:29 PM(UTC)
The optic boards control power to the ice maker. The status LED shows the status of the optic boards. While the optic beam is open, the LED should be steady On. If it's blinking, then there is something wrong with he optic boards. They should be replaced together.
If you would like, unscrew the freezer light bulb and repeat this test. If the LED will keep blinking, perform the tests described in the step 3 of the attached tech sheet.
File Attachment(s):
Guest (4)
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by gmpfeffer 2/24/2013 1:42:19 PM(UTC)
kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by Kewoldt 12/3/2011 7:13:17 PM(UTC)
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Dan54 2/28/2011 11:39:01 PM(UTC)
KitchenAid icemaker not working (Refrigerator & Freezer Repair)
by Anilkumar15 12/31/2010 5:44:41 PM(UTC)
by jjjacek 6/5/2010 4:45:22 AM(UTC)
Kitchenaid Icemaker Not Working (Refrigerator & Freezer Repair)
by Doug_dallas 6/8/2009 2:00:59 PM(UTC)
by jayconnor 12/30/2007 7:15:37 AM(UTC)
