Dryer stopped working during a load had 1 mnute left on timer. turned it off unplugged it plugged back in, powers up all diplays work, light comes on and goes off when door is operated. Push start button ...nothing cant get a code either. Control board was replaced 3 months ago by service company
Hello, Remove the top panel and check the belt. If the belt is broken, the dryer would never work. - The belt Part number: 8547168
Thanks Gene, I will check but wouldnt the motor still try to run?
No. It has a broken belt switch which interrupts power to the motor.
Thanks Gene!! will look tomorrow
