AkZipper
#1 Posted : Thursday, November 29, 2012 4:14:41 AM(UTC)
AkZipper
I have an older high efficiency Kenmore Gas dryer that has been giving me issues. I have read all over this forum to try to find the solution, but haven't had any luck.
I've replaced the solenoids, the flame sensor, and the ignitor already.
The dryer will start up fine, rotate without issues, and the ignitor will glow red, however the gas does not ever ignite (I don't know if it ever even starts coming out).
At times I do "think" I hear a gurgling noise (whether this has to do with it or not) towards the end of the ignition cycle.
Is it possible I received bad solenoids? I bought them for 10 bucks off of amazon. Do I need to check them? Any other thoughts of what could be wrong? Thanks so much for the help!
Simon / APP Team
#2 Posted : Thursday, November 29, 2012 1:24:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the coils continuity and see if you didn't forget to put back on the double coil shaft the metal insert.
If everything looks OK - you need a new gas valve.
Provide the model number for the correct part number.
Simon.
AkZipper
#3 Posted : Monday, December 3, 2012 4:57:32 PM(UTC)
AkZipper
The model is 110.94832201 . I'll check the continuity tomorrow. Thanks a lot for the help!!
Simon / APP Team
#4 Posted : Tuesday, December 4, 2012 1:05:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the gas valve assembly for your dryer
Part number: 280119
Part number: 280119
Post the results.
Simon.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Hotpoint gas dryer no heat (Dryer Repair)
by Erich4130 8/28/2013 3:45:28 PM(UTC)
by huggard42 5/30/2013 4:34:58 PM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
Kenmore Gas Dryer No heat (Dryer Repair)
by Resultsnow 9/8/2012 11:14:56 AM(UTC)
Gas dryer no heat (Dryer Repair)
by Brent gordon 7/31/2012 1:36:06 PM(UTC)
by petec357 6/21/2012 3:05:37 AM(UTC)
Frigidaire gas dryer no heat (Dryer Repair)
by mbarone 3/18/2012 4:25:38 PM(UTC)
my whirlpool gas dryer no heat and wont shut off (Dryer Repair)
by phyllisl 3/8/2012 6:13:19 AM(UTC)
