shannonsjackson
#1 Posted : 12 years ago
shannonsjackson
The dryer will not heat. I can turn it on and the drum spins. Nothing else happens. No click or any other sound. The drum will just spin.
I have replaced the solenoids, ignitor and the flame sensor. Still a no go. The ignitor does not glow at any time.
Is it something in the controls on top? Help :(
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's a blown thermal fuse (#7 on the diagram)
Part number: 3392519
Use the video clip for the instructions.
Here are the breakdown diagrams and Bulkhead parts for Whirlpool WGD5540SQ0 - AppliancePartsPros.com
Post the results.
Simon.
shannonsjackson
#3 Posted : 12 years ago
shannonsjackson
The thermal fuse was bad, no continuity. Found a local shop that was open late and picked up a new one. Installed and everything is working!
As I think back on why this might have occurred, I think the dryer vent was probably smashed (it is one of the soft foil ones). I placed a piece of a 2X4 on the floor behind the dryer so the wife can't accidentally push it back too far again.
Thanks Simon!
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
You are welcome.
And you are correct - the restriction in the air flow will cause the fuse to blow.
Simon.
gas dryer will not ignite (Dryer Repair)
by daughdrill1 11 years ago
Gas Dryer will not ignite (Dryer Repair)
by bnhandyman19 11 years ago
by JoshK 12 years ago
