shannonsjackson
#1 Posted : Monday, November 26, 2012 3:18:47 PM(UTC)
shannonsjackson
The dryer will not heat. I can turn it on and the drum spins. Nothing else happens. No click or any other sound. The drum will just spin.
I have replaced the solenoids, ignitor and the flame sensor. Still a no go. The ignitor does not glow at any time.
Is it something in the controls on top? Help :(
Simon / APP Team
#2 Posted : Monday, November 26, 2012 4:12:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's a blown thermal fuse (#7 on the diagram)
Part number: 3392519
Use the video clip for the instructions.
Here are the breakdown diagrams and Bulkhead parts for Whirlpool WGD5540SQ0 - AppliancePartsPros.com
Post the results.
Simon.
shannonsjackson
#3 Posted : Monday, November 26, 2012 6:42:55 PM(UTC)
shannonsjackson
The thermal fuse was bad, no continuity. Found a local shop that was open late and picked up a new one. Installed and everything is working!
As I think back on why this might have occurred, I think the dryer vent was probably smashed (it is one of the soft foil ones). I placed a piece of a 2X4 on the floor behind the dryer so the wife can't accidentally push it back too far again.
Thanks Simon!
Simon / APP Team
#4 Posted : Monday, November 26, 2012 8:29:07 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You are welcome.
And you are correct - the restriction in the air flow will cause the fuse to blow.
Simon.
gas dryer will not ignite (Dryer Repair)
by daughdrill1 5/11/2014 6:50:39 PM(UTC)
Gas Dryer will not ignite (Dryer Repair)
by bnhandyman19 11/23/2013 2:35:57 PM(UTC)
by JoshK 10/22/2012 7:51:48 AM(UTC)
