KItchen Aid KUDS30IXSS blew the thermal fuse. I passed this off to a power outage. Now the fuse blew again. This particular fuse did not come with the replacement pigtails, so I was wondering where else I should be looking. Apparently, replacing the board is not the answer since I have checked out other posts. Is it possible the drain is clogged, not letting the motor move? Is there somewhere else I can look at the same time? THX
What is the part number of the thermal fuse you installed?
What is the end of the model number?
Originally Posted by: Gene  What is the part number of the thermal fuse you installed?
Gene. Part number is W10402110 Complete model number is KUDS30IXSS4
