1 year old kitchen aid DW recently started making a loud water noise. it sounds like there is water running very near the surface (outside of the machine)/a possible leak, but i can't identify any actual water anywhere. we've checked under the DW (no water) and the wood housing is dry. how concerned should I be? it occurs when the machine is filling, but no so much when it is actually washing. the sound seems to be coming from the front left top area. any advice appreciated.
It can be a sound of the water entering the dishwasher. If it is than it's normal.
