curtisn
#1 Posted : Tuesday, November 20, 2012 3:00:41 PM(UTC)
curtisn
I have a Kitchen Aid Side by Side Freezer/Fridge and the door gasket seal on the fridge side (lower part of door) has worn out. From looking at the door it looks like the existing gasket seal is held in place by adhesive and I believe I just need to remove the old gasket by peeling it off and cleaning up area to remove and sticky residue and then just install new (I assume new has adhesive on one side) Is this correct?
Thanks for any help in advance
C
rickgburton
#2 Posted : Tuesday, November 20, 2012 5:54:11 PM(UTC)
rickgburton
Groups: Expert
Probably no adhesive but would need your model number to look it up. I believe it just pushes into a grove all the way around the door.
curtisn
#3 Posted : Tuesday, November 20, 2012 6:18:25 PM(UTC)
curtisn
Model Number KSRB25FKSS04
rickgburton
#4 Posted : Tuesday, November 20, 2012 6:26:59 PM(UTC)
rickgburton
Groups: Expert
Pushes into the channel around the door with no adhesive.
curtisn
#5 Posted : Tuesday, November 20, 2012 6:39:16 PM(UTC)
curtisn
So I just pull old out (brute force) and muscle the new one back in? Can I leave the door on?
