hemion20s
#1 Posted : 16 years ago
hemion20s
Im building a new house and just got my frigidaire slide in stove with convection oven installed. I flipped the breaker on and the oven display shows line err (I looks like line anyway) . I've looked through all the books that came with the stove but can't find anything on this. Can someone help me?
I believe the model number is PLES389EC. I will go ride to the house later to double check the number
#2 Posted : 16 years ago
A Model Number may help find some info for you.
hemion20s
#3 Posted : 16 years ago
hemion20s
can anyone help with this?
#4 Posted : 16 years ago
Here is a service manual which may help
http://www.frigidaire.com/tip/s...ric%20Ranges_Rev%20A.pdf
I could not find an error with just lines
First thing to do is check the power
Make sure you have 240 volts between L1 and L2 AND 120 volts between L1 and Neutral AND L2 and Neutral
Frigidaire error code f11 (Oven Repair (including Ranges and Cooktops))
by bbcci 12 years ago
Frigidaire Error Code - E47 (Washer Repair)
by Scotts_Spot 13 years ago
Frigidaire Error E47-Spin Cycle (Washer Repair)
by amarkscpa 14 years ago
Frigidaire error code E14 (Washer Repair)
by stevemckeown 15 years ago
frigidaire error code F10 - not listed in your error codes (Oven Repair (including Ranges and Cooktops))
by Skully26 16 years ago
frigidaire error e10 (Washer Repair)
by jeannesalisbury@gmail.com 16 years ago
Frigidaire Error Code F20 - Upon Cleaning (Oven Repair (including Ranges and Cooktops))
by Bryan Pierce 16 years ago
Frigidaire error F-9 (Oven Repair (including Ranges and Cooktops))
by fix it mom 17 years ago
