hemion20s
#1 Posted : Friday, April 10, 2009 8:35:00 PM(UTC)
hemion20s
Im building a new house and just got my frigidaire slide in stove with convection oven installed. I flipped the breaker on and the oven display shows line err (I looks like line anyway) . I've looked through all the books that came with the stove but can't find anything on this. Can someone help me?
I believe the model number is PLES389EC. I will go ride to the house later to double check the number
#2 Posted : Saturday, April 11, 2009 1:08:16 AM(UTC)
A Model Number may help find some info for you.
hemion20s
#3 Posted : Saturday, April 11, 2009 4:22:49 PM(UTC)
hemion20s
can anyone help with this?
#4 Posted : Saturday, April 11, 2009 6:36:15 PM(UTC)
Here is a service manual which may help
http://www.frigidaire.com/tip/s...ric%20Ranges_Rev%20A.pdf
I could not find an error with just lines
First thing to do is check the power
Make sure you have 240 volts between L1 and L2 AND 120 volts between L1 and Neutral AND L2 and Neutral
Frigidaire error code f11 (Oven Repair (including Ranges and Cooktops))
by bbcci 8/9/2013 4:45:22 AM(UTC)
Frigidaire Error Code - E47 (Washer Repair)
by Scotts_Spot 1/10/2012 6:19:20 PM(UTC)
Frigidaire Error E47-Spin Cycle (Washer Repair)
by amarkscpa 10/25/2010 11:30:24 PM(UTC)
Frigidaire error code E14 (Washer Repair)
by stevemckeown 10/28/2009 4:19:28 PM(UTC)
frigidaire error code F10 - not listed in your error codes (Oven Repair (including Ranges and Cooktops))
by Skully26 5/18/2009 1:11:21 PM(UTC)
frigidaire error e10 (Washer Repair)
by jeannesalisbury@gmail.com 3/22/2009 6:42:48 PM(UTC)
Frigidaire Error Code F20 - Upon Cleaning (Oven Repair (including Ranges and Cooktops))
by Bryan Pierce 12/3/2008 4:46:28 PM(UTC)
Frigidaire error F-9 (Oven Repair (including Ranges and Cooktops))
by fix it mom 2/18/2008 7:35:24 AM(UTC)
