MWalton954
#1 Posted : Thursday, October 25, 2012 6:43:55 AM(UTC)
MWalton954
Good Morning,
My dryer quit working last week. I have power to the terminal block. I checked my Thermal Fuse and it too is good. I mean I have power to the dryer but the drum light doesn't even come on when the door is open. What can you suggest as a logical check next? Thank you.
Matt
Simon / APP Team
#2 Posted : Thursday, October 25, 2012 3:49:43 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the drum light bulb (t's maybe bad).
Check the door switch:Blue to White continuity with door closed, no continuity with door open.
Check for 120VAC at the PCB contacts P9-2 (black) and P8-3 (white). If the correct voltage present - replace the PCB.
Here are the breakdown diagrams and 01-Top and Console Parts parts for Maytag MED6600TQ0 - AppliancePartsPros.com
The PCB is #17.
Simon.
MWalton954
#3 Posted : Monday, November 5, 2012 6:17:45 AM(UTC)
MWalton954
Simon,
I tested and replaced the PCB. Dryer still will not turn on. Do you have any other suggestions? Thanks for your time.
Matt
Simon / APP Team
#4 Posted : Monday, November 5, 2012 9:33:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Did you check the door switch?
When you checked the voltage at the terminal block what was the reading? Did you have 240VAC?
Simon.
Dryer will not turn on. Please HELP! (Dryer Repair)
by greatdeals_007 10/20/2011 6:57:18 AM(UTC)
