Good Morning,
My dryer quit working last week. I have power to the terminal block. I checked my Thermal Fuse and it too is good. I mean I have power to the dryer but the drum light doesn't even come on when the door is open. What can you suggest as a logical check next? Thank you.
Matt
Groups: APP Team
Hi. Check the drum light bulb (t's maybe bad). Check the door switch:Blue to White continuity with door closed, no continuity with door open. Check for 120VAC at the PCB contacts P9-2 (black) and P8-3 (white). If the correct voltage present - replace the PCB. Here are the breakdown diagrams and 01-Top and Console Parts parts for Maytag MED6600TQ0 - AppliancePartsPros.comThe PCB is #17. Simon.
Simon,
I tested and replaced the PCB. Dryer still will not turn on. Do you have any other suggestions? Thanks for your time.
Matt
Groups: APP Team
Hi.
Did you check the door switch?
When you checked the voltage at the terminal block what was the reading? Did you have 240VAC?
Simon.
